  1. I am looking at two capture cards:
    Terratec Cinergy 400XE (SAA7134) and Leadtek Winfast TV2K Expert (CX23881). Afaik the Conexant has a 10bit ADC and the Philips a 9bit, nevertheless people say the image quality of the Philips is slightly better. How come?
    I am planning on using it to capture from a Sat Receiver thru RFout (worse quality) or Scart (better). Which one of the two cards do you recommend?
    Final output will be MPEG2 for DVD authoring or possibly MPEG4 for a standalone DVD Player with Mpeg4 support. PC is fast enough to encode in realtime (2.6C, 1GB DDR466)
    Thanks for any advice.
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    There are about the same
    Conexant CX23881 has better 3rd party support
    Philips SAA7134 support PAL needs better (overall)
    So, for the PAL users, you have a better chip (conexant) vs a PAL optimised chip (philips).
    Later drivers always eliminate the difference on this, but the first impressions are always what stays in the minds of the users.
  3. thx satstorm,
    after reading a bit, i found out that the current Conexant drivers do not support the full 10bit capability of the Adc, but i'm sure the future ones will. So with this thought in mind i think i'm gonna settle for the Leadtek (Conexant)
