I had successfully the VCD conversion from 29.97fps AVI to 25fps PAL MPEG1 using TMPGENC.
The results differ from PC viewing and one from TV (Multi System).
View from PC, the screen same as those from original AVI, while the TV had top and bottom portion truncated (missing).
I tried convert it again to NTSC, and same bad results.
Anyone know what is the cause of this problem?
Could it be overscan? Every TV cuts out top, bottom, right and left portion of the picture - it's simply out of the viewable area. How much depends on make and model, but all leave some out. Most noticeable if you've placed subs at the absolute lower edge of the picture. "Real" TV productions make sure that nothing significant goes on at the edges of the screen.
/Mats
[SOLVED] Weird difference in gamma(color) output
By ladjack in forum Software PlayingReplies: 1Last Post: 7th Mar 2011, 08:16 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 19:31 -
TMPGEnc Authoring Works v4 – weird warning.
By redpol in forum Authoring (DVD)Replies: 2Last Post: 18th May 2010, 09:05 -
Weird subtitle colors when authoring a DVD
By dexter30 in forum SubtitleReplies: 4Last Post: 22nd Feb 2010, 22:54 -
weird subtitle error during authoring of a DVD
By michcio in forum SubtitleReplies: 2Last Post: 26th Oct 2008, 08:11
