hello everyone!!
I was wondering if anyone has used avi-mux gui to change framerate? if so is it good and is it easy for a newb to use? thanks in advance
I use AVI MUX GUI all the time and I'm relatively sure that you can't change frame rates with it. Use Virtualdub instead but you will have to use a seperate audio editor to change the audio frame frate. Vdub only changes the video frame rate. Once you have both the audio and video converted, then use AVI MUX GUI to combine the two.
I was probably getting confused. trying to follow a guide for changing ntsc 23.97 & 29.97 to pal and part of it was using avifrate to change the fps, I cannot get avifrate to open so I did a search and avi-mux gui came up it does say "allows changing framerate" so I presumed it might work the same way. I'm using tmpgenc but they come out jumpy like it needs speeding up a bit
thanks for reply
AVI-Mux GUI problem
By toni-boy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Oct 2010, 12:37 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Alternative to AVI-mux GUI?
By badreligionhead in forum Video ConversionReplies: 3Last Post: 8th Dec 2009, 12:30 -
Question why AVI-Mux GUI cuts down file size
By jimdagys in forum EditingReplies: 2Last Post: 16th Apr 2009, 03:18 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
