Results 1 to 16 of 16
    I can burn a disk with nero to a + or - disk with no problem. I can also burn a +RW disk and the disk works with no problem but after it is finished burning it just hangs up the computer. Nero says it is completed and I can move the mouse but can not activate any buttons on nero or anywhere else on my computer and I can not eject the disk. If i press the reboot key on my computer then I can eject the disk and it plays fine. I got a pioneer A06 burner.
  2. Why are you not upgrading to 6.3 builds ? there has been numberous fixes since your version
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    well I went back to 6.0.0.0 and it works now. Maybe I should go back to 5.5 and get even better results
  4. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Not a bad idea. I went back to 5.5.10.42 and am very happy.
  5. Banned
    Jan 2004
    Going in Circles
    you are missing the point. As was pointed out earlier, you need to update nero 6. Bugfixes and new features are always coming out.
  6. Banned
    Jan 2004
    Going in Circles
    sefy, you can only do so much. He needs to pack his computer up and send it back where he got it.
  7. One can only offer assistance, can't force it
    Best Regards,
    Sefy Levy,
    If I wanna take a sledgehammer to my computer I can. It is my business. For some ODD reason nero 6.3 dont install on my computer. Screw it. It is not too important as long as 6.0 can burn a dvd that is all I need.
  9. Banned
    Jan 2004
    Going in Circles
    it is called operator error
  10. Personaly I wouldn't use Nero to burn DVD's at all, it's compatibility level is absolutly hurrible. I Prefer CopyToDVD instead, easier, faster and a hell lot more compatible 8)
    Best Regards,
    Sefy Levy,
  11. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    troyvcd1 is right, you can find 1000's of posts on these boards almost equally split between all the major backup software "religions" like Nero, DVD2ONE, Shrink, Copy2DVD, and on, and on, and on. Same way with media, Intel vs AMD, capture devices, et al.
    Use what you like.
  12. @Jayhawk, I think you got me a bit wrong here, I love Nero, I use it to burn my images and some VCD's as well, mostly all my DataCD's I do with it, but I found during my short period of DVD burning, that it simply does not create that good compatibility with players.
    Best Regards,
    Sefy Levy,
    I have never had any compatibility problems with my pioneer and good media. I never had one problem yet. I have not tested my dvds on too many other players. I guess I will continue using nero till I have a problem.
  14. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    Sefy, My comments weren't directed at you. I actually agree with you completely regarding Nero which is why I use Decrypter and Shrink. I just get frustrated sometimes with all the "I use this and you should too" comments I see on the boards. troyvcd1 seems comfortable back at Nero 6.0.0. which seems to bother gitreel. I'm pretty sure it doesn't affect the quality of my life so I don't really care what troyvcd1 does.
  15. @Jayhawk, no worries!
    Everyone to himself as they say
    Best Regards,
    Sefy Levy,
    Apr 2004
    Trinidad - West Indies
    hello there all :] .... just passing through.... I have that same problem with nero, it burns good up to the last and then the color led goes from red to orange... if it's real bad it will hang and not recover.... and through careful examination i realise that it happens if im burning on the fly at the max speed ( 4x ) and this happens too burning from the hard disk..... so i just burn at 2x or 2.4x ... so far it's going good... i have a lite-on
    nice to meet you all.... take care :]
    Marcus
