As I found this feature of chaptering every 10 min very convinient, I used this on a few DVDs.All of these DVDs have problems, independant of Media and burning method.Without this feature they work fine.
The problems are either a short stop every 2 min or so on one player, or a complete freeze on another one.In the PC everything plays fine.
Rewinding just before the troublesome spot and then playing works until a next (normally 2 min further) is reached.
After Reauthoring (demuxing the DVD on to HDD and then Reauthor - without autochapter) everything is fine.
Any ideas, what's happening?
You have a cheap DVD player, no? Some don't like authoring software's chaptering. I had to basically throw out my apex for a Toshiba because I couldn't stand the problem. AFter getting a better brand player every chapter point works like a charm.
I do not think tmpgenc is the problem. I use auto chapter for 2 mins, 3 mins, 4 mins, 5 and 6 on several dvd. And my movies played fine on sony (3 models), panasonic (2 models). This is not include few DVD I send to my friends and I have no ideal what brand names they use but non of them complaint about chapter.
Something else cause the problem? -
I don't really know.Only DVD authored with autochapter don't work.All other DVDs (either different Authoring tool or manual chaptering) do work.
I tried everything with the same media (DVD+RW) and different burning tools:the same results.
Auto-chapter (on scene change) w/ eg. Matroska?
By Gew in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2010, 11:46 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 21:44 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Tmpgenc DVD Author 1.6 How Do I Move a Chapter One Page Over
By sneed in forum Authoring (DVD)Replies: 14Last Post: 3rd Nov 2007, 08:47 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
