I downloaded several *vob Files, ripped from a dvd. Some of them wont play anyway. With use of the DVD Patcher Program i found out, that they seem to have no "sequence header".
The Main File is 947 MB big. I tried several DVD Software Players and several Video Programs to read the Properties of the File (Virtual Dub, AviCodec...) but none worked with the File, expect the DVD Patcher, which tells me of the missing sequence header.
Anyone got an Idea if and how to repair this file ?
Results 1 to 10 of 10
Ok, a problem occured. The DVD consists of 3 Main VOB files. 2*0,99GB (named VTS_01_1.VOB, VTS_01_2.VOB and VTS_01_3.VOB) the 3rd is 947 MB and is the one with the problem. When demuxing with settings "demux all video and all audio streams" it demuxes the First File, even if 3rd file is opened. when trying to rename the files, so that 3rd file is the first, it demuxes the renamed 3rd, but all demuxed files are empty, 0 byte big.
I see. When i do so, it demuxes the first two and the File which is broken, is beeing ignored.
On an FTP, sharing Video projects. I am a doing Videos in my Free Time, short storys, for fun. And u use DVD for burning them in Digital Video QUality. Thats where the Vobīs are from ^^
Tried with DVD Lab. Good Program. It also tells me, that the Headers are missing and tells me to use the "Fix Header Option" in the "tools". Unfortunately this tool only works for mpv and m2p files.
Seems as there is no way of fixing a missing header in a vob file... any further ideas ?
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 12:23 -
Video track header missing in MP4 file
By MaNuHelp in forum EditingReplies: 6Last Post: 17th Apr 2009, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 08:30 -
Audio missing in VOB file
By marknyc5 in forum DVD RippingReplies: 3Last Post: 20th Jul 2008, 20:48 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 17:02
