hi, i am trying to burn a 702mb iso vcd onto a 700mb cd using nero version 6. everytime i try to burn on a bulkpaq cd i get error saying the disc does not have enough space, insert another disc. i thought nero should give an option that allows you to overburn slightly on a 700mb, so why cant i burn 702 mb on a 700mb cd? i am using my nec 1100a dvd burner to do it. i have a cdrw in another computer i own would i be better off using that to burn on? i have ticked to box in nero which says finalise the disc.
I need to assume you have access to Nero Express - this is what I use.
Go into Nero and when you're ready to burn the image, click the "More..." button then the "Configure" button. Click the "Expert Features" tab and activate overburning. Set your limits, and away you go!
If you're using ordinary Nero, go to File --> Preferances. You can then click "Expert Features" and select overburning.
Hope this helps!
Cobra -
Some Nero 6 version have a bug when trying to burn a cd on which data size is close to cd size.
Update to the latest version 6.3.1.6 to resolve this problem.
PS: a 80 min cd has a capacity of 703 MB in data mode and 807 MB in vcd/svcd -
i have got overburning selected in nero, do you think my nec 1100a could be unable to overburn? overburn is definately selected in my nero expert features. would i be able to extract the contents of the iso to my harddrive?Originally Posted by Cobra
Like I said before, update to the latest version of nero 6 (some of the first releases had problems with overburning).
Nero ISO file Issues!
By lapetite_66 in forum ComputerReplies: 8Last Post: 23rd Feb 2011, 12:56 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
How do I make a 700MB+ video file to a 700MB video file?
By riahc3 in forum Newbie / General discussionsReplies: 26Last Post: 2nd Jul 2009, 21:55 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 22:49
