Hi guys,
i hope someone can help me....
After using Tmpg the Audio of the Movie doesn't fit with the video. Why is the audio displaced?
Thx
Basically, deckard8 is correct, but it's VBR audio that gives TMPGEnc trouble, mostly. But most inportant q is: What are you trying to encode? If it's an AVI, have you made sure it's error free?
/Mats -
Find out more about the movie...
If your trying to encode NTSC as PAL, or the other way around - you will get an a/v sync error.
Avi-files: Gspot (open or drop movie)
Mpg-files: VirtualDub-MPEG 2 (open movie, then File/File information)
Depending on what output you want (PAL/NTSC), you may have to do a framerate conversion of both video and audio....000....000....
Angelot :-D -
It happens to me sometimes when I convert the already converted video. So What I do is to convert the video using STOIK, it's free, but the video quality sucks. After that I open it on premier, then unlink the video and audio, then export only the audio as wav file. Then open TMPGEnc, open your original avi,(not the STOIK one) then open the wav file that was converted by premier. It will work now.
Converting TS to MKV - video is shaky and seek doesn't work
By Scorpick in forum Video ConversionReplies: 11Last Post: 5th Mar 2012, 19:11 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18 -
Extracted WAV doesn't fit to original video!
By GangstaRap in forum Video ConversionReplies: 24Last Post: 15th Jan 2008, 20:24 -
subtitle that doesn't fit
By Belfour in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 09:30
