what drivers or files does the TMPGEnc DVD Author writer tool uses?
i think i need to remove the driver or file use to burn DVd that that program uses
does anyone know how to?
In my experience the tmpgenc dvd author writer is not that good, I would use a program like nero or stomp record now max.
HardCoreRuss,
Not to start a war but, I only use TDA and I have not had any problems with it todate. Granted it is not the top of the line unit but then I was not expecting that level of capability either.
To the original poster, use the OS system Program Remove utility and you will get rid of TDA. Then you can install / use any other burning software you like. To me TDA is fairly benign and seems to work with other writing software. I also use Record Now (for data records), VCDEasy for VCD (when I was doing them). And they all worked together just fine.
Ed. -
Each to their own Ed, it was only a personal opinion. I love Princo discs and everyone slates them
HardCoreRuss,
I appologize if it sounded like I was starting a war, I was not. Like you just offering up my .02 FWIW. More power to the English language.
I was attempting to tell the poster that by removing TDA he could use any burner he wanted if it was currently conflicting with TDA and tell (vice show) of my experience with TDA and other burners. No qualifications here. I just ain't that sharp. When it works, I use it. If it doesn't I get rid of it. Fairly simple for me. Has to be. :grin
