Are these the current driver for the optorite DD0203
When i goto Device manager and click the properties
and then the driver tab and then driver details for the optorite DD0203
the following file are located are displayed and located
in the system32/driver folder
Bsstor.sys
cdrbsysd.sys
cdrom.sys
gearaspiwdm.sys
imapi.sys
pxhelp20.sys
redbook.sys
storpro.dll
i'm having this problem I'm currently using TMGENC DVD Author writing tool to burn my own video_ts and Audio_ts folder. Is there any other program that allow you to burn your own audio ts and video ts which will play on a stand alone DVD player? Please post thanks.
Why i'm asking , because when i use TMGENC DVD Author after a while my optorite DD0203 DVD/CD-RW stops working. yes my drive have stop work at one point and some how i got it to work again I think it might have something to do with ASPI drivers
Do all burning program use ASPI or is it the CD/DVD writer device that need to use the ASPI drivers?
Results 1 to 1 of 1
