ok so i have downloaded a couple of avi's whose frame ates are 29.971. I want to make these into SVCD's am i able to do that without the sync getting messed up? cause i am pretty sure you need to have it in NTSC (29.97) for mplayer to decode.
also on files that are not NTSC (29.97) i now get a vop not coded message in the info when it is encoding.. what does this mean?
Same thing here. The avi files I have are only 24min, so I can't see any difference at all. For longer movies you could open the audio and video in QT Pro, add scaled the audio to the video and export the audio back out. It should fix any problems with sync.Originally Posted by dr9553
The problem isn't mplayer, it's with mpeg2enc. It only accepts standard frame rates.
cool. but everytime i try to decode something with quicktime i get this error:
Encoding started on Mon Apr 26 18:01:54 CDT 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
im not sure why. I have always gotten this too. Is there a plugin i am missing in my quicktime folder?
Frame rate question
By janlafata in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2009, 19:37 -
Idx/sub frame rate
By -Sandro- in forum SubtitleReplies: 7Last Post: 30th May 2009, 15:32 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15 -
nero frame rate
By bong1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 30th Jul 2007, 16:50
