I was just wondering how to make two DVD's into one. What I have is about a 30 Sec spot that I want to put before about 2 hrs of footage. What I did was Rip the 2 hr footage using DVD shrink and then the 30 sec footage into a seperate folder. I went into the VIDEO_TS folder with the long footage and changed the VOB files up on # (ex. VTS_01_1 to VTS_01_2) then went to the VOB file for the small 30 sec clip and added it to the VIDEO_TS folder as VTS_01_1. I then burned it to DVD using CopytoDVD and the first 30 sec spot played fine but then the movie behind it was all jacked up. If anyone can help I would greatly appreciate it... Thanks for the help... Phil
DVD2ONE is a great program for just such a purpose. Just use the join feature and you can order it however you wish. I recommend using seamless join instead of append to next title set. Also you can use intervideo's dvdcopy platinum 2. It supports unlimited video_ts folders while making a single dvd. I hope that this helps.
If in doubt, Google it.
I got it to work just using DVD shrink Ver 3.1 Pretty easy... Thank you guys for your time...
