Hi budies, I have some video in format .mov. ok here are the questions.
Can I change the format mov to avi ?
How can I change my old movie VHS to DVD ?![]()
Originally Posted by newguy1
You can capture your footage on your computer then burn it with a DVD writer. This can be difficult for a beginner or newbie.
Get a DVD recorder and feed your vcr into it. Simple, easy and good results."Art is making something out of nothing and selling it." - Frank Zappa -
If the VHS is protected with Macrovision you will also need a SCART-cable that disables MV between the VHS-player and the DVD-recorder.
See http://www.ktvision.com/standard.html....000....000....
Angelot :-D
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
