I'm new to sony vegas and would like to know if I can set the frame track to show EVERY frame. At the moment it doesn't do this. It only shows a picture that covers a few seconds of movie.![]()
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
...or grab the edges of your scroll bar and make it smaller, or position the cursor where you want and turn your scroll mouse wheel.
Thanks Freestyler, I've just tried that but it's still out with the main picture.
When I use TMPG Author it has the perfect frame track to edit with. I really want something like that. Also, if I zoom in as you suggest, is there a way of locking that settings?"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Thanks guys, I'm starting to get the hang of it. All handy hints welcome, so keep them coming
Alt + Up Arrow (keep clicking up arrow a few times) will make it 1 frame view ...
i dont know of anyway to lock it though -- just dont change it .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 18:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00 -
Sony Vegas Users? Simple editing question...
By jnaizer in forum EditingReplies: 12Last Post: 25th Oct 2008, 16:07 -
Need input from SONY VEGAS 8 PLATINUM users -- not pro
By jg0001 in forum EditingReplies: 0Last Post: 23rd Nov 2007, 11:10
