I still cant seem to get iti want to add audio to my menu background pictures in TMPG authour and i have asked on here and searched on here but it still aint workin for me, first i use tmpgnc plus to encode a jpeg picture with a wav file so it can be used in tmpgen authour, that bit works fine but when the dvd is created the audio plays for a fraction of a second, its literally a blip then nothing, i have set the motion menu setting to well over 30 seconds, so its not that, CAN ANYONE help me out, its really bugging me, any help would be much appreciated!!!!
How long is your original Wav file?
Is it encoded at 48000 to be compliant with DVD?
I have done this and it does work (pain in the behind though). DVD Author is a great program but this is a MAJOR flaw in my opnion that you can't add audio to your menu in a simple way. -
I always find it easier to just make the motion menu in my video editing app. and output it as MPEG-2, complete with audio then just set the timeout length of the menu to match that file.
It's just easier than screwing around with it seperately.
So since you are just doing pictures as backgrounds. Go into your video editing application. Drop the picture on the time line, drop your sound on the timeline and then just stretch your picture's view time to match the sound file. Output it to MPEG-2. OR.....output it to AVI, then use TMPGEnc Plus to seperate the sound and video. -
yes its at 48000 and its about 3.5mb long but it could shortened, it even plays in the check box that appears when you click on it in the program but when created to burn to a disc it doesnt play!!!, what is a good simple to use video editing application, i only use winDV to capture then convert using tmpgenc plus , then its straight into authour, thanks for helpin out i know its a much talked about topic but i just cant get it somehow!!!
You can download several that are trials. Ulead Video Studio, Pinnacle Studio 8, Adobe Premiere.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
Continuous audio throughout menus
By dth122 in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 23:34 -
Need to rip audio from menus
By jmelly in forum ffmpegX general discussionReplies: 1Last Post: 10th Jan 2009, 16:46 -
Add new audio track and keep menus
By Kim Dung in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2008, 05:47 -
Can Audio Be added to DVD Menus?
By Scav2003 in forum Authoring (DVD)Replies: 2Last Post: 4th Apr 2008, 17:59
