Hello again. I'm trying to edit mpeg2 footage in Premiere but it plays very badly, jerky etc.
Are there some settings I need to change?
.....x
mpg2 is not a good format for editing. you will run into problems. what is the footage you are trying to edit? was it originally a dv avi file from your camcorder? if it was, keep it as an avi file, avi's are much easier to edit in premiere. also, please describe your problem more. is is always jerky? or just when you try to preview effects?
is the video jerky before you edit it? like if you play it in media player? if so, then the video file itself is damaged, and im afraid your screwed then. if it only happens in premiere, try editing the footage, and then exporting it. sometimes premiere acts wierd until you export the whole file. btw, what version of premiere are you using?
Skippy/Jumpy Render output Issue Premiere CS5 to MPEG2
By dragan1975 in forum Video ConversionReplies: 8Last Post: 24th Dec 2011, 18:39 -
Edit MPEG2 in Premiere...
By arminio in forum EditingReplies: 2Last Post: 21st Dec 2011, 01:45 -
Premiere Pro on OSX - mpeg2 clip audio missing
By Mylo in forum EditingReplies: 2Last Post: 17th Feb 2011, 06:00 -
Premiere Pro CS3, MPEG2 to DVD, which field first?
By trikcard in forum Video ConversionReplies: 3Last Post: 18th Sep 2007, 23:29 -
Problem with Mpeg2 Premiere Convert
By drgregur in forum Video ConversionReplies: 0Last Post: 27th Jul 2007, 14:04
