Results 1 to 30 of 48
  1. After using shrink i opened xcopy and could not see how to openthe files on my hard drive to burn the dvd using x copy
    May 2003
    Peterborough, England
    Why are you trying to use DVD X Copy to burn? Why not just use Nero or whatever you normally use to burn? DVD Shrink has done all the hard work for you. You will either have a VIDEO_TS folder with the files in it or a set of bup, ifo and vob files. If you have the folder already, just burn it to DVD, if you only have the files, burn them to DVD in a folder called VIDEO_TS.
    Alternatively, if you have Shrink 3.1, let it do the burning for you.
  3. I am confused because as far as i can tell you cannot burn with shrink it only decryptes the files to a iso dir on the hard drive. I have bought the dvd xcopy last year and cannot return it so I am trying to find out how to burn with xcopy after using shrink to convert.
  4. Banned
    Jan 2004
    Going in Circles
    actually you can burn with dvdshrink. You need to get dvdshrink 3.17
  5. Banned
    Jan 2004
    Going in Circles
    I would throw away dvd x copy. Dvdshrink will do everything. Dvd x copy is only for people who don't know any better.
    Monroe, Mi
    dvd shrink and a burning program is all you need to backup dvds. you do not need dvdxcopy of you are using shrink, its crap anyways. after you run teh dvd through shrink and get the dvd file size down to 4300mb or whatever size you want to use, just open nero and burn the dvd files you just created. yes dvd shrink 3.1.7 can burn itself, but i dont like it, i use nero to burn.
  7. I am afraid that you are wrong about shrink it does not burn you have to use something like Nero or DVD Decrypter
    Aug 2003
    Canada
    dvd shrink does burn
  9. All you need is DVDecrypter installed on your comp. When you get to the Backup DVD dialog box in DVDShrink version 3.17, just tick "launch DVDDecrypter to burn the output image".
    Pull! Bang! Darn!
  10. I'm a Super Moderator johns0's Avatar
    canada
    Dvdshrink uses nero to burn with,not by itself.
  11. Banned
    Jan 2004
    Going in Circles
    The point I was trying to make is that you could use Dvdshrink 3.17 to shrink the movie and burn it all in one program. There is no need to launch nero separately, because the burning engine has been put into shrink.
  12. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    gitreel, are you sure about that,
    i thought that shrink uses nero or dvddecrypter to burn
    Twomilepost,
    What burner software came with your dvd burner ? use that (you do have a dvd burner right)
    or if you have nero use that with dvdshrink or get DVDdecrypter (its free) and use that to burn using dvdshrink
  13. Banned
    Jan 2004
    Going in Circles
    Dvdshrink has the nero burning engine built in.
  14. Banned
    Jan 2004
    Going in Circles
    sifaga, why don't you download the newest dvdshrink, and you will find out. I never make statements that I am not sure about.
  15. Originally Posted by gitreel
    Hmm, just for fun I opened a DVD in DVDShrink 3.17, went to preferences and enabled burning with Nero. When I hit backup I was informed "To enable burning, please install Nero". Guess it ain't in Shrink.
    Pull! Bang! Darn!
    Oct 2003
    Somewhere Else
    Hi there,
    I think that to use Nero with DVD Shrink, you need to have Nero installed. Shrink is making calls to the Nero engine, but it does not install nero for you.
    I can't see nero giving away the engine for free (Be nice if they did thugh)
    kosekjm
    BTW, never tried burning with DVD Decrypter as I have Nero on my machine. It works great with Shrink 3.1.7
  17. Originally Posted by kosekjm
    Yes, of course. Either you're very polite or you missed the sarcasm. :P
    Pull! Bang! Darn!
  18. Banned
    Jan 2004
    Going in Circles
    OK forgive me, you must have nero installed. But once you do, shrink will do it all.
  19. Hello There: Why would you want to use DVD SHRINK with Xcopy? DVD X COPY makes 1:1 BACKUPS of your DVD movies. You don't need anything else. DVD SHRINK is excellent also. It just doesn' t have a burn engine with it. I prefer DVD DECRYPTER, DVD2ONE and IMGTOOL in conjunction with each other. LATER.
  20. Banned
    Jan 2004
    Going in Circles
    Yes but with dvd x copy, usually you need more than one dvd.
  21. Banned
    Jan 2004
    Going in Circles
    I do not understand why anyone would use dvd x copy. You have to pay for a program that does half as good as the ones that are free. Read my lips.......Dvd X Copy suxxxxxxxx......
  22. Member glockjs's Avatar
    Feb 2004
    the freakin desert
  23. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Use dvdshrink, then do what BIGTIME said, burn with dvd decrypter. You can set it to do this. and both are free.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  24. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I just fell out of my chair !
    If in doubt, Google it.
  25. Banned
    Jan 2004
    Going in Circles
    you did not read my earlier post, you must have nero installed. then shrink uses nero, thus burning it all at once, saving having to open nero separately.
  26. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    FYI, I read the whole post.
    You are soooooo FOS. STFU NOOB !
    one program uses another program (therefore, two programs), thus it's all in one ?
    where/when did youy learn basic mathematics ?
  27. This is a great thread
    I think gitreel will make an excellent politician one day
    Even a fool can be wise, all he has to do is keep his mouth shut
  28. Just wanted to thank everyone for the information even the ones who confused me even more. I think it is clear to everyone that I wasted my money last year buying x copy but that was last year, now its shrink, dvd decrypter or nero. Thanks from the newbe
  29. One last thing how is dvd decrypter with performance? Do you loose many dvd's or is it as good as nero? Don't want to have anymore coasters thanks
  30. Member
    Apr 2004
    Here is the true low down. Dvd X Copy the ripper version is one of the best shrinking software available. Much better quality than dvd shrink. All you need for burning a single layer (5) dvd is Dvd Decrypter. It does a perfect 1 to 1 copy. Yes if you shrink with another program and use Decrypter to burn it is very high quality.
