I have stomp record max now to create video dvds
I have a pioneer a05 writer and use 4x disks, when burning starts the time left for completion will be around 15mins, but after a while it boosts up to over 30mins and even 45mins so it cant b writing at the full speed
Im sure i have the latest firmware too
Can u suggest anything? or anyother software thats worth using?
Lee
I sometimes have that happen when it's writing to a bad batch of discs.
I've noticed that the Time Remaining and % complete isn't very accurate.
I look at my discs under light before burning them. If they look like they
have some blotchiness or swirls (especially towards the edge), chances
are greater that they won't burn properly. This is only from my
observation, but I've found it to be pretty accurate, at least on my burner
(Lite-On LDW451S)
I had a bunch of bad discs which I took back and exchanged. The new
batch has been working great. So far I've had 22 straight "Good" burns.
The quality of discs from batch to batch isn't consistent.
-LouV68 -
try Ulead DVD MOvie Factory 3.....it does everything, from dvd authoring to dvd burning....I start to like it more that Nero.
you can try it for free at www.ulead.com
RAW MiniDV recorder software for Windows
By eadmaster in forum Capturing and VCRReplies: 1Last Post: 8th May 2011, 02:22 -
Whats the best screen recorder software for high quality video?
By peteman in forum Newbie / General discussionsReplies: 8Last Post: 20th Jan 2011, 14:51 -
Mac Software that Encodes like a DVD Recorder
By Gypsy898 in forum MacReplies: 4Last Post: 13th Aug 2009, 22:31 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
