I am searching a simple method to backup DVD with original menu using TMPGENC.
I would like to use the TMPGENC to recompress the movie in order to fit in one DVD. The good software DVDShrink is great but when the compression ratio is about 55%, the final quality is reduced. And the TMPGENC gives enough good quality for such low data rate so I could fit the whole movie (about 2:30 hours) in one DVD.
I was able to use TMPGENC and IfoEdit to make a new DVD without original menu (this method allowed me to keep the multiple AC3 sound tracks and original chapters). Now, I would like to keep the original menu. Is it possible to compress the main movie using TMPGENC and to recombine the result back to original DVD? I found similar guides but the guides were for CCE, not for TMPGENC.
Thank you ahead for your responses.
Results 1 to 1 of 1
Searching for DVD Box set
By Arok01 in forum ComputerReplies: 5Last Post: 20th Mar 2011, 11:26 -
SEARCHING: DVD Software WITHOUT re-encoding MPEGs
By jouse. in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2010, 04:57 -
Searching for Specific DVD Recorder Device
By SupaDupaMonkey in forum DVD & Blu-ray RecordersReplies: 8Last Post: 27th Jul 2009, 16:58 -
searching for DVD Recorder cctv 24/7
By madsharpei in forum DVD & Blu-ray RecordersReplies: 1Last Post: 22nd Aug 2007, 12:50 -
searching for a DVD player website
By solution81 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th May 2007, 13:27
