I'm using dvd author and have a warning
came up...The Video Gop is to long, i read
in a guide you wont know if your software
will do this till you try, then it tells you what
to do if it does.
If i ignore this what effect would this have in
my final DVD?
THANKS
We're Bought and Sold
For English Gold. -
I've had that happen a couple times. I ignored it and burned the final disk to a RW disk to test it. It still works in all my standlone players (and in software players).
Open the video in a bitrate viewer and see for yourself (may be a TDA hoax). NTSC DVD GOP is 18 frames max, PAL 15. If it's true, you'll be authoring at your own risk. It may work or not (some players are more tolerant than others).
When you convert from SVCD, this is a common problem. Outside of reencoding, I don't know how to fix. I ignore the GOP size and it has always worked. May be some players that don't like it.
I thought there may have been a risk, i checked
the box for my next clip, i'll let you know what happens.
I'm also checking out the birate viewer....
thanksWe're Bought and Sold
For English Gold.
Video is blurry on computer but clear on HDTV, how can it happen?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 12:48 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 13:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 03:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 06:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 19:32
