I don't know if this forum is strictly appropriate for this subject, but I am still fairly new, so bear with me.
At the moment, it is taking my computer about 65 or so minutes to perform a deep analysis on a given DVD, depending on how full the disc is. Assuming the film itself takes six gig, it generally takes about 60 minutes... I haven't found a film yet that has been allocated eight gig, but I assume it will take at least 70. While this isn't a problem most of the time, I would like to be doing other things with at least part of that time.
I also find that when I burn at 4X, the size of my buffer seems to go up and down a lot, as if the processor can't get the information from my hard disk to the IDE controller to the drive quickly enough with the processor it has.
All of which brings me to my pertinent question. I have been contemplating upgrading my processor ever since I bought the DVD drive, but aside from video applications, I can't see any reason to do so. Currently, I have a AMD Duron processor rated at 850Mhz, and it runs all my word processing, database, even still graphics functions fine. But for a DVD analysis to take over an hour, let's just say that's an hour I could be using to do something else, such as editing my first novel.
So, my question is pretty simple. First, will a processor upgrade be of any benefit to me in terms of speeding up the backing-up process? Second, what's a realistic processor speed to put in for DVD backup and recording applications? I think my current motherboard can support speeds up to 1.8 Ghz, but I'd have to confirm that.
Results 1 to 9 of 9
Generally speaking the quicker the CPU the quicker the encode. My XP 2000 takes about 40 mins to backup a full DVD with deep analysis.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
If your m/b supports CPUs up to 1.8GHz, go out and buy one now. The price will most likely be a bargain and in a few months you won't be able to find any CPU below 2.4GHz. And then you will be thinking of replacing your whole system.
850MHz is rather on the low end for any video related work and the times you quote are typical of the CPU power.
If you are using DVDShrink, use the latest version, configure it to run at a low priority and it will whistle along at a lower pace while you will be able to do anything on your PC. Typing in a word processor or browsing the internet takes minimum CPU percentage anyway.The more I learn, the more I come to realize how little it is I know. -
I'm willing to bet that the people complaining of pixelisation are compressing their films by as much as 50% or so. I've never had a major problem with the video output as long as I only compress the video to the bare minimum that I need in order to fit it onto one disc (usually 20% extra compression or less).
I've been reading the product literature for my motherboard, and it looks like I am going to have to update the motherboard, too. -
UPDATE:
My motherboard's maximum CPU rating is about 1.4 Ghz, and I don't think it is worth the hassle of going onto Ebay to find such a chip. The question is where to find a motherboard and processor that all my other components are compatible with... -
1.33 GHz Athlon, $39:
http://www.newegg.com/app/viewProductDesc.asp?description=19-103-156&depa=0 -
It is worth the extra money (if possible) to upgrade the core of your system: motherboard, processor and memory.
Even going up to the 1.33 Athlon should make a noticable difference. -
A note here: I am not in the USA.
If you walked into an Australian store and told them you wanted a 1.33 Ghz processor, they'd more than likely tell you that you cannot get one anymore. If you told them you wanted a processor for $39, or even $69, you'd get laughed at. A lot.
I'd like to avoid getting new memory if I can help it. DDR RAM is also expensive here.
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 11:09 -
Please help: slow megui encoding on Quad Core
By bremler in forum Video ConversionReplies: 8Last Post: 4th Mar 2010, 00:56 -
Encoding with VirtualDub the second time around is very slow
By Megahurts in forum EditingReplies: 9Last Post: 6th Mar 2008, 23:02 -
WinFF encoding slow???
By Megahurts in forum Video ConversionReplies: 1Last Post: 30th Dec 2007, 23:17 -
Xvid encoding going extremely slow..
By daking in forum DVD RippingReplies: 11Last Post: 11th Jun 2007, 10:27
