Results 1 to 14 of 14
Originally Posted by short360Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
Don't think it's a video file extension. check here :>
http://filext.com/detaillist.php?extdetail=SWS -
I think that the sws is part of the file name, the extension is almost certainly avi. I am betting on this file being some sort of screener or cam.
not to sure about sws but the ts part normally stands for telesync don't know if thats any help
Originally Posted by HardcorerussFight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
ok found out it was a rar file used winrar extracted it it turns out to be a bin and cue file. so ive used isobuster extracted the movie file but it shows as a notepad file it plays through media player but TMPGEnc wont reconise it and i want to put it to dvdr can anyone help me with that. and yes i did download it. thanks
There's nothing you can do then. Delete it and go get on with something else.
EDIT forget that posted before your post came through.
If you goto say 'My Documents' and click on tools at the top and select 'folder options'. Click the view tab and uncheck the box which says ' Hide extensions for known file types ' .
Then you can see what the file extensions are. -
Originally Posted by empnc
We usually punish those who talk about warez. Warez includes non legal downloaded movies.
Use DVD2Avi, import your mpeg2 file and create a project file. This spits out a .d2v file and an mpa file with the correct audio delay information. If wanted to you could use avisynth with the d2v file to throw in a couple of noise filters and a resize filter. Considering we know what the file is and where came from, the quality is well...
Import the d2v file into TMPG and encode away.
Check the guides for how to use DVD2Avi, and for proper VFAPI installation.
If it's mpg1 (352x240), don't bother, not worth it, or use Virtualdub then either frame serve, or resave as an avi. <- Check the guides for how to frame serve with V-Dub.
.MEV movie file?
By ChaunceyK in forum Newbie / General discussionsReplies: 10Last Post: 20th Aug 2011, 14:36 -
Can't play movie file
By Edward256 in forum Newbie / General discussionsReplies: 9Last Post: 18th Apr 2011, 19:29 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
Movie File Size?
By LCE in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 13:13 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 00:18
