Results 1 to 9 of 9
  1. Because I didn't see a specific forum for DVD Burning, I'm putting this here.
    I'm looking for a program (didnt see one in tools) that will create a DVD directly from an AVI, MPEG, or other video format. I have Sonic MyDVD which will do this, but I don't like it.
    If I have to encode the video first, say the program will only accept videos in DVD standards, thats fine. But I need a PROGRAM (not a tutorial or method), that will allow me to select a video, then burn that video as a DVD. I DO NOT WANT SOMETHING THAT REQUIRES ME TO MESS AROUND WITH VIDEO_TS FOLDERS OR .IMG FILES!
    FROM VIDEO FILE TO DVD
    Any suggestions?
    [/url]
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you are prime customeer for a standalone dvd recorder
  3. Originally Posted by BJ_M
    key word being program
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    josh23
    kinda bold for your second post
    nero+plug-in's
    canada
    Tmpgenc dvd author sounds like a program suited for you,just pop in the dvd compliant mpg files and it will create the folders and right after it is finished doing this it will bring up a dialogue box so you can burn right away.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    doesnt sound as if he has compliant dvd files is the issue
  7. Originally Posted by josh23
    Any suggestions?
    [/url]
    I don't think there is a program which does all of this, you will have to use a culmination, such as tmpgenc, tmpgenc dvd author, nero.
    If it's wet, drink it
    My DVD Collection
    Dec 2002
    My Swamp
    If Sonic DVD does what you want , why exactly do you not like it ?
    It would be helpful to know. Is it a time issue or quality issue or what ?
  9. tmpgenc,tmpgenc dvd author,
    dvd-lab,copytodvd,dvd2one,dvddecrypter,ifoedit,vobedit.
    you try the programmes,and find out whats best for you,instead of asking someone to tell you what prog to use.
    if you like one,use it.
