I'm having problems with microsoft word, it says Not enough memory when i try to "Save AS" or print. I need to fix this so bad, I'm a script writer and director and am shooting in a month. I need to get this fixed fast, i need like 10 scripts printed like tomorrow, i have to do a read through with my cast thursday.
Results 1 to 10 of 10
Can you cut and paste from word. If so cut and paste it into like notepad or another program and print from there
I can't the only thing big enough to handle it is WordPad, but theres a problem with that too. But i could just save it in a regular notepad file in like 4 parts
Thanks for the idea.
Hi
I encounter this problem quite often. In almost every instance MS Word or Excel is complaining about not enough memory, the c:\windows\temp directory is too full. Word can't handle the fact that the temp dir gets full. So just close all apps and delete all files in c:\windows\temp.
You'll notice a lot of zero lenght files in the temp dir but in fact hese aren't 0 bytes. Depending on the filesystem (FAT, FAT32 etc)) and the size of the partition, these zero lenght files can take up to 32 Kb per file.
cheers
Leo -
Thanks,
It didn't help though.
Right now i'm trying to download some service files from micrsofts website, hopefully that will work. -
Ther service files from microsoft didn't work, i'm downloadind rambooster now.
the only time i've seen an "out of memory" message on my win98se machine (256mb ram), was when i was using tmpgenc to join two large mpegs. i got around it by increasing my fixed size swapfile/pagefile from 512mb to 1024mb (min 1000mb, max 1024mb). obviously, the disk space has gotta be there beforehand...
Word Association
By MackemX in forum Off topicReplies: 16525Last Post: 15th Dec 2025, 14:09 -
What do you use for a software word processor?
By johns0 in forum PollsReplies: 12Last Post: 22nd Feb 2012, 04:36 -
Microsoft Word
By didikai in forum Off topicReplies: 9Last Post: 11th Apr 2009, 22:40 -
Beep out a word in Avi
By lud6328 in forum AudioReplies: 3Last Post: 27th Apr 2008, 17:46 -
Microsoft Word experts!
By jyeh74 in forum Off topicReplies: 7Last Post: 16th Apr 2008, 15:02
