I have photos in J-Peg form on CD/R/RW and would like to be able to play them on to the TV, is this possible if so what type of player would I require.
Results 1 to 12 of 12
What do you mean what kind of player do you need? if you want to create a slide show to play on a dvd player than it has to read vcd or dvdr/w. You can created a slide show on either of the two. Hope this helps.
Originally Posted by yan
Check through the players section along the left of the screen and you can compare compatibility with the different media. -
Hi x21x and Capmaster
Thanks for the reply I will have to convert my J-Pegs into a slide show. Do you know if I will be able to get enough on a CD or will I require a DVD writer instead. -
Buy yourself a cheap DVD player that will play jpegs burnt to CD or DVD as data. Thats what I did mine will even play them as a slideshow rotate them flip them mirror them zoom in and pan, and it only cost £37. I bought it specifically for viewing my jpeg photos. No messing around with authoring discs as slideshows just burn them as jpegs to the cd and view, simple.
Thanks Craig
So that means a CD with J-Peg photos saved to it in windows XP will play on a DVD player that plays J-Pegs, that sounds the easiest way to go.
What make of player did you buy?. -
Here is a thread I posted on my player a little while back.
https://www.videohelp.com/forum/viewtopic.php?t=190300&highlight=akura -
Yan, one of my players will do that as well. It's an Apex AD-1200 and will play JPEGs and MPEGs burnt as data, it will display a list you can select from. It has folder mode, repeat folder, repeat one and shuffle play. Organize your files in folders and name them. Too easy.
Your chances are best with the cheap Chinese-made players. Got mine for about $40 a year and a half ago. Models change so frequently my specific model number won't help you, look for a cheapie with JPEG support.Pull! Bang! Darn! -
But it does not need to read DVDR/RW
My primary DVD player at the workbench is still an Apex AD-1100W, and it plays everything.
Figure if you can buy it for less than £50 and it's a name you've never heard of, you're safe. -
Thanks once again all of you, this information has been very helpfull.
I will see what machine I can source in my area (Norfolk) now that I know what to look for thankyou. -
With Nero Vision Express 2 you can make your own slideshow with jpeg's (and other) + audio and burn it in any format (SVCD,VCD,DVD) on every standard (+/-/RAM) with menus and the lot, and play it on a standalone DVD-player.
www.nero.com...000....000....
Angelot :-D
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:09 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
DV Playback?
By reubenray in forum Capturing and VCRReplies: 11Last Post: 9th Nov 2007, 09:42 -
playback on tv
By andyluong99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 16:08
