hello, need help fast.![]()
We just got a standalone DVD recorder Luxor (LUXDVR1203).
This works fine, but I want to copy the DVD+RWs it produces on my NEC recorder on my coputer.
I am unable to run it throught DVD Shrink (and other dvd copy progs) as I get a message about 'navigational problems'. I try to copy out the files but the last VOB file can't be copied.
The DVD+RW works fine on other standalone players, only my computer does not like the last VOB, I have tried several disks.
Why doesen't the Luxor write standard DVD format disks? I find files in there (a secound dir) that should not be there. Is there a way to 'finalize' or 'close' the dvd-rw so that I can copy it?
On the Luxor I can 'make compatible' but that doesen't do any difference concerning this problem.
I need to know if this is an issue with all standalone recorders. If not, we'll get another, if yes... well...![]()
I am very disappointed.
Pleace help! As we have to return the Luxor in a few days...
hakon
Sounds like it might be an incompatible file format ...maybe proprietary. I'm not familiar with Luxor so I don't know.
Only DVD-R and DVD+R can be "finalized". I would suggest trying this:
1) Try it with a finalized DVD-R.
2) Check your standalone recorder options and make sure that you're recording in the DVD-Video format. I've only heard of .VRO files when a DVD-RW or DVD-RAM is recorded on a standalone. -
Thanks for you reply, I'll test a DVD+R later today. Do I have to accept that I cannot copy DVD+RWs made on a standalone recorder? any info on this?
Here's the content of the DVD+RW:
Dir VIDEO_RM
-SONATA.IFO
-SONATA_DEBUG.IFO
-VIDEO_RM.BUP
-VIDEO_RM.DAT
-VIDEO_RM.IFO
Dir VIDEO_TS
-VIDEO_TS.BUP
-VIDEO_TS.IFO
-VIDEO_TS.VOB
-VTS_01_0.BUP
-VTS_01_0.IFO
-VTS_01_1.VOB
-VTS_01_2.VOB
-VTS_01_3.VOB
-VTS_01_4.VOB
-VTS_01_5.VOB
Cannot copy VTS_01_0.BUP as it is "corrupted or does not exist" same goes for VTS_01_5.VOB.
When attepting to open disc in DVD Shrink 3.1: DVD Shrink encountered an error and cannot contiue. Invalid navigation structure
Could I only copy that VOB I'd be helped, but...
DVD Lab says: Cannot open file, File in use? (about the 5th VOB file)
This is very annoyoing, any suggestions are are greatly appreciated.
-hakon -
I can't speak for DVD-RW but I can copy DVD+RW discs recorded on my Philips DVDR75 to my laptop no problem using DVD Decrypter.
The .BUP file is a backup file- it's exactly the same as the .IFO file with the same name. If it's corrupted you can make a copy of the VTS_01_0.IFO file in another folder, rename the copy to VTS_01_0.BUP and move that back to the VIDEO_TS folder.
Can't help you with .VOB problem. -
Sorry everyone it's DVD+RW... I have now changed my first posts.
Thanks BobK this worked, now the only complaint Nero has is that damn VOB file... the DVD+RW works fine on my Thomson standalone.... -
Have you tried DVDDecrypter to copy the vob file? I've had some files that it would get 30-40 errors trying to copy and then it would get it. Others times it won't work either, but it might be worth a try.
Experiences with selfmade Blu-Ray discs and standalone players.
By quantumfire in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jul 2009, 08:28 -
standalone 16:9 recorder
By dnyboy in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th May 2009, 13:37 -
Formatting DVD+/-RW discs on Recorder
By mukeshs in forum MediaReplies: 2Last Post: 28th Dec 2008, 11:05 -
My standalone DVD Recorder is a
By Baldrick in forum PollsReplies: 31Last Post: 12th Nov 2008, 15:21 -
DVD Recorder Standalone
By ebob in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 11:40
