I have two files, both are DVD MPEG2 compliant which I encoded with TMPGENC. I deleted the original AVI's after conversion. When I went to join them with TMPGENC an error said that I cannot join these 2 files, they are different. I noticed that by accident I converted 1 file in 4:3 and the other in 16:9, I want it to be 16:9, is there any way to change this without having to re-encode the entire file???? Please I hope there is, I can't beleive I missed that, all that time wasted......![]()
Thanks to all that take the time to help me with this, I really appreciate it.
Hi averyisiah,
When you encode, part of that encoding is the aspect ratio (4:3 or 16:9). SO, if you've encoded to 4:3 in error, then (IMO) I'd say that there's now way around it other than to re-encode from the source to 16:9 ratio.
BUt, as you've binned your original (lesson learned there - we've all done it!) I think (don't know for sure) you may be able to use TMPGEnc to re-encode the MPEG2 in 4:3 to MPEG2 in 16:9. If you can, I don't know what the resultant quality will be like.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
dvdpatcher can change the AR settings in mpg files - might solve your problem (depends weather tmpec added the black bars on the 4:3)
Apologies averyisiah - I stand corrected.
Cheers Roderz - Useful to know...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
How do I convert a M2TS file that seems to be messed up
By BirdDaddie in forum Video ConversionReplies: 6Last Post: 28th Aug 2010, 16:32 -
Bad .vob .mpg file playback, colors messed up
By lindylex in forum EditingReplies: 2Last Post: 30th Dec 2009, 09:56 -
converting flv to avi, speed messed up, whats wrong?
By lurky in forum Video ConversionReplies: 2Last Post: 13th Aug 2008, 00:16 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
