Page 4 of 5
FirstFirst ... 2 3 4 5 LastLast
Results 91 to 120 of 129
    Mar 2004
    Canada
    Originally Posted by gitreel
    yes wendi, TMPGenc will convert that file to mp2 provided you have toolame.exe. TMPG sometimes have trouble on it's own so you use toolame to convert it.
    i hope this posting does not bring me to page 5 or Andyp1 and Roderz will never let me live it down
    I do not understand how you use toolame and tmpgenc at the same time. I went to read about toolame but found a small file to download, this is not an actual software? How is it used in conjunction with tmpgenc.
    How can I printer-friendly print off all these pages of postings???
    Computers #$@%^$$#@## :)
  2. Banned
    Jan 2004
    Going in Circles
    It is too real software. I use it all the time. In TMPG go to environmental Settings, audio engine. It is an encoder. Make sure you direct TMPG to this executable file.
    Mar 2004
    Canada
    Originally Posted by Roderz
    Now you know the steps you shouldn't have any probs
    a. Know your source
    b. get the audio to your format
    c. calc bitrates
    d. encode mp2
    e. author
    you might have gone the long way round but you have done every step (at least once) if not in the right order.
    (I wonder if the audio is going to be in sync )
    ahhhh Roderz you opened another can of worms.
    d. encode mp2 - i am encoding with tmpgenc and it's output file is an mpg.
    and what if the audio is out of sync??? OMG!!!! you are freaking me out now. lol don't leave me hanging.
    Mar 2004
    Canada
    ok!!
    not sure which toolame to download, the page has many of them.
    I will try this if tmpgenc author does not take my wav and if the audio is out of sync.
    thank you !!!
  5. Banned
    Jan 2004
    Going in Circles
    if it does not work, then demux and start over again.
    Mar 2004
    Canada
    keeping too many trains of thoughts at same time, getting a little lost.
    i was told not to demux when saving an mp3 to a wav, just save it as a wav.
  7. Banned
    Jan 2004
    Going in Circles
    The output of the mpg if demuxed, will be m2v, and mp2
    Mar 2004
    Canada
    LOL sometimes I am so smart I am stoopid.
    The reason why I could not author my avi file was because... cough cough, yes I am admiting this.... because it was not finished encoding yet. Ooops.
  9. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    Just bring your m2v (not the avi) and wav file togeather in TDA - all should be fine.
    Dam I thought I'd of got top of the page agian
    Dec 2002
    My Swamp
    It just the terminology
    put simply - Demux just means seperate the audio from the video.
    Remux means joining the audio and video together.
    So for an Xvid with mp3 audio you would seperate the audio and convert it to a .wav
    or Demux and save as wav.
  11. Member Roderz's Avatar
    Jul 2003
    Not if its encoded as ES video only (see previous post)
    Tada PAGE 5
    Dec 2002
    My Swamp
    Mar 2004
    Canada
    oh oh !!!
    well one worked perfect. the one that was avi > mpg and the audio was ac3
    as for the avi > mpg that audio was mp3 converted to wav . . . well the damn file is too big.
    dvdshrink didn't really help - only good for dvd files. i need to shrink it before authoring
    gadzooks
    so close
  14. Member Roderz's Avatar
    Jul 2003
    NO stop wait
    author the dvd (yes its going to be to big - do not try and burn it).
    Then run dvd shrink on the author'd folder - lot quicker then encoding again.
    Dec 2002
    My Swamp
    DVD Shrink can do it. Once you have your VIDEO_TS folder you can use Shrink.
    Open DVD Shrink
    Open File
    Find your VIDEO_TS folder you have just created
    IT will scan the folder
    Set the compression to custom
    Drag the slider to the left till the file size is small enough to fit on a DVD-R
    Hit Back-Up
    Voila
    Mar 2004
    Canada
    NO stop wait
    ok it is authoring right now. it gave me a warning about illegal.... out of standard dvd.... i just said iggy that and now it is authoring.
    i have authored one, authoring a second now, and encoding 2 more. woohooo i am on my way
    Mar 2004
    Canada
    Open DVD Shrink
    Open File
    Hit Back-Up
    Voila
    thank you !!! i guess i have to author it first, which i am doing now.
    now, how can i print out these 5 pages?????? so the words do not run off the right hand side of the page.
  18. Member
    Dec 2002
    My Swamp
    Correct.
    I think it will be a lot more than 5 pieces of paper.
    I hope youve plenty of ink.
    Printer setings - landscape instead of portrait
    or copy & paste into word
    Mar 2004
    Canada
    okeedokee
    Mar 2004
    Canada
    Andyp1
    I am using DVDshrink 1.02. I do not have all those options you mentioned. Which version are you using and from where did you get it?
    Wendi
    Mar 2004
    Canada
    forget last post, i figured it out
  22. Member
    Dec 2002
    My Swamp
    Yours is an old version try 3.1.7 from this page - http://www.dvdshrink.info/downloads.php
  23. Member lacywest's Avatar
    Aug 2001
    California
    EEEEEH .... Wendi ...
    Well your typing skills will be improved ... your reading skills will be improved ...
    Your supply of printer INK will be lower ... your paper supply will be lower.
    But all in all ... your learning ...
    But now ... do you understand ... why I just use InterVideo WinDVD Creator 2 ... he he. And you get to output the audio to AC-3 when converting.
    Not to confuse ... But you can also use Nero Recode 2 ... to shrink the final results.
    Or you can use ... InterVideo DVDCopy 1.2b.
    Dont use version 2.0 ... it leaves artifacts and pixelated images.
    Reason to suggest InterVideo DVDCopy 1.2b ... is because I've made some projects with TMPGEnc DVD Author ... that were really big ... and DVDShrink and Nero Recode 2 ... didn't accept them.
    But ... InterVideo DVDCopy 1.2b ... did accept the challenge with success.
  24. Member lacywest's Avatar
    Aug 2001
    California
    Originally Posted by wendi
    Andyp1
    Wendi
    Hang onto version 1.02 ... there has been times when I had to use version 1.02 ... this version wont analyze the DVD-VOB files when it first starts up.
    The newer DVDshrinks ... do ... and if you have a mistake in the DVD Rip ... the newer DVDshrinks ... will stop.
  25. Member
    Mar 2004
    Canada
    what exactly do you use that windvdcreator for lacy???
  26. Member
    Mar 2004
    Canada
    GUESS WHAT???????????????????????????????????????????
    IT WORKED !!!!!!!!!
    OMG
    My dvd i burned today played AWESOME in my standalone!! This was my avi file with ac3 audio.
    Next is to burn and view my avi with mp3 audio that I had to extract the audio and save as a wav and then was TOO big. It authored great, DVD shrink worked, so I will burn it and then I am ON MY WAY!!!
    All that is left to learn is how to take a FPS25 Pal and convert it so I can use NTSC!!!!
    I want to thank EVERYONE for being so unbelievably patient and helping me. I am going to watch my flick now in my dvd player
  27. Banned
    Jan 2004
    Going in Circles
    I am glad it worked for you, whatever you did. Just remember to do that again and you won't go wrong.
  28. Member
    Mar 2004
    Canada
    Thanks Gitreel.
    I burned my avi that had mp3 audio and i had to save it as a wav. I burned it today after using dvdshrink, so hopefully that one will work too, then i am sooo on my way.
    next: pal > ntsc. I will have to harrass roderz for that one.
    Thank you for helping this canadian chickie. I owe a huge thanks to andyp1, roderz, lacywest ... if I forgot to mention any, I thank you too, lol, can't see all 5 pages right now to see who helped me.
    OMG 5 pages. Now I have to go print them ALL out so I don't lose this valuable information.
    wake up roderz pal > ntsc is next
    I will read the guide you recommended this weekend.
    wendi
  29. Member
    Mar 2004
    Canada
    Ok, I printed out these 5 pages of postings.
    any guesses as to how many pieces of paper it took?????
    23
