My DVD created using MOTV will not play in my Meridian G98. I see the root menu, but I get no navifational controls. I hear the background audio stream and if I select each album using the Track access button, then it plays the MOTV movie perfectly.
It's just the menus.
I've tried MOTV and NERO to burn, but get the same problem. I think that there's something non-compliant in the MOTV coding for menus.
Can anyone recommend either:
1) an alternative package as good as MOTV that works with menus.
2) any suggested configs etc that may solve the problem.
(The disk plays OK in older players, the meridian is DVD-Rom based. I get the same error using PowerDVD as the PC viewer)
Try asking MOTV at:
http://www.picturetotv.com/support.htm?
Have use used other programs that produce working menus? If you have, you could use MOTV to make the MPEG2 files and make the menus and burn with the other program.
I use Ulead Movie Factory 2 to create menus and burn MOTV slideshows.
menus with VIDEO_TS playback in VLC possible?
By wcndave in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2009, 10:37 -
DVD memories - the early days!
By lordsmurf in forum MediaReplies: 5Last Post: 14th Jan 2009, 23:06 -
Memories on TV Pro v4 Problem
By davequa in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 22:00 -
Memories on TV Photo Slide Show program, help??? Please.
By vanc in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2008, 13:34 -
Memories to TV mpeg quits at 27 %
By pcbrown in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 07:54
