Results 1 to 13 of 13
  1. Hi there.. I rebooted my computer from scratch and had it customly built, I have a DVD rom drive and a CD-WRiter 48x12x48x drive, but I don't know the make of my cd writer, and thus I can't find the drivers for it.. So i can't copy stuff onto cds, can anyone help me and tell me what I can do? :/
    Mar 2004
    go to start/control panel/ then click on system, and go to hardware tab, then device manager, look under cd-roms should show the make of your drive, it does on mine anyway
  3. Ah you're right, its an Artec WRR-4848
    How would I go about getting the latest driver?
  4. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Louise01 you could do a search on Google for drivers for your drive, but don't really get your hopes up on finding any.
    The drive itself should already be supported on your system and you will probably only need the lastest version Aspi Layer installed on your system to make it more compatible with the Burning Software that your gonna use.
    Again do a search for that on Google or your could go here.....
    www.adaptec.com
    and use the search option at the top to look for Aspi Layer
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
  5. I used that ASPi checker thing and it says
    Component APIX.VXD version 4
    WNASPI32.DLL Version 1 , is that any use? :/
    Mar 2003
    Uranus
    It would help to know what OS you are using
  7. Windows ME at the moment )
    and thanks alot guys, i am so stupid with computers
  8. Originally Posted by Louise01
    Confucius said: "He who asks a question is a fool for but five minutes; he who asks not shall remain a fool forever."
    Cobra
  9. After trying to burn a clip onto the cd this is the results from nero
    Nevzat 23
    Windows 98 4.90 (ME)
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 08/06/2000 17:00:00
    ahead WinASPI: File 'C:\PROGRAM FILES\AHEAD\NERO\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
    Nero version: 6.3.1.6 (Nero Express)
    Recorder: < RW-481248> Version: 1.07 - HA 0 TA 1 - 6.3.1.6
    Adapter driver: <ESDI_506> HA 0
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <SONY DVD-ROM DDU1621 >Version: S2.9 - HA 0 TA 0 - 6.3.1.6
    SONY DVD-ROM DDU1621 (Target 0, D: Autoinsert Off, DMA On, Disconnect ?, SyncDataXfer ?
    RW-481248 (Target 1, E: Autoinsert Off, DMA On, Disconnect ?, SyncDataXfer ?
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 74448896 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 511MB (523704kB)
    Free physical memory: 241MB (247020kB)
    Memory in use : 47 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    20.4.2004
    CD-ROM (ISO)
    01:53:58 #1 Text 0 File Isodoc.cpp, Line 6062
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : FALSE
    Multisession : TRUE
    Multisession type: : Start multisession
    Burning mode : TAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    01:53:58 #2 Phase 89 File dlgbrnst.cpp, Line 1841
    Super Link activated
    01:53:58 #3 Text 0 File Reader.cpp, Line 118
    Reader running
    01:53:58 #4 Text 0 File Writer.cpp, Line 124
    Writer RW-481248 running
    01:53:58 #5 ISO9660GEN -11 File geniso.cpp, Line 3898
    First writeable address = 0 (0x00000000)
    01:53:59 #6 Text 0 File Burncd.cpp, Line 3198
    Turn on Track-at-once, using CD-R/RW media
    01:54:12 #7 Text 0 File DlgWaitCD.cpp, Line 244
    Last possible write address on media: 359845 ( 79:59.70)
    Last address to be written: 6752 ( 1:32.02)
    01:54:12 #8 Text 0 File DlgWaitCD.cpp, Line 249
    Write in overburning mode: FALSE
    01:54:12 #9 Text 0 File DlgWaitCD.cpp, Line 2107
    Recorder: RW-481248;
    CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
    ATIP Data:
    Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
    Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    01:54:12 #10 Text 0 File DlgWaitCD.cpp, Line 410
    >>> Protocol of DlgWaitCD activities: <<<
    Insert the disc to write to.
    (Medium in drive: Unknown. Medium required by compilation: CD-R/RW.)
    01:54:12 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original disc pos #0 + 6753 (6753) = #6753/1:30.3
    relocatable, disc pos for caching/writing not required/required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 6751 blocks [ RW-481248 ]
    01:54:12 #12 Text 0 File ThreadedTransferInterface.cpp, Line 982
    Prepare recorder [ RW-481248 ] for write in TAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc not fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 14137344, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
    -150 | lead-in | 0 | 0x00 | 0x41
    -150 | 1 | 0 | 0x00 | 0x41
    0 | 1 | 1 | 0x00 | 0x41
    6753 | lead-out | 1 | 0x00 | 0x41
    01:54:12 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1028
    Removed 2 run-out blocks from end of track 1. Length: 6753 -> 6751.
    01:54:12 #14 Phase 24 File dlgbrnst.cpp, Line 1841
    Caching of files started
    01:54:12 #15 Text 0 File Burncd.cpp, Line 4214
    Cache writing successful.
    01:54:12 #16 Phase 25 File dlgbrnst.cpp, Line 1841
    Caching of files completed
    01:54:12 #17 Phase 36 File dlgbrnst.cpp, Line 1841
    Burn process started at 48x (7,200 KB/s)
    01:54:12 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2342
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    01:54:12 #19 Text 0 File Mmc.cpp, Line 19864
    Set BUFE: Super Link -> ON , Generic write control : ON
    01:54:31 #20 SCSI -1106 File Cdrdrv.cpp, Line 1437
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02530000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x73
    Sense Qual: 0x03
    CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
    0x00 0x00 0x00 0x00 0x73 0x03
    01:54:31 #21 CDR -1106 File Writer.cpp, Line 304
    Power calibration error
    01:54:31 #22 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    01:54:31 #23 CDR -201 File WriterStatus.cpp, Line 196
    Invalid write state
    RW-481248\H0 T1
    01:54:31 #24 TRANSFER -18 File WriterStatus.cpp, Line 196
    Could not perform EndTrack
    01:54:31 #25 Text 0 File Mmc.cpp, Line 14708
    < RW-481248 > start Close Session
    01:54:31 #26 SCSI -1176 File Cdrdrv.cpp, Line 1183
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x72
    Sense Qual: 0x04
    CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
    0x00 0x00 0x00 0x00 0x72 0x04
    01:54:31 #27 CDR -1176 File WriterStatus.cpp, Line 245
    Session fixation error
    01:54:31 #28 TRANSFER -19 File WriterStatus.cpp, Line 245
    Could not perform Fixation
    01:54:31 #29 Text 0 File WriterStatus.cpp, Line 254
    falling back to disc fixation
    01:54:31 #30 Text 0 File Mmc.cpp, Line 14708
    01:54:31 #31 SCSI -1176 File Cdrdrv.cpp, Line 1183
    Sense Code: 0x72
    Sense Qual: 0x04
    01:54:31 #32 CDR -1176 File WriterStatus.cpp, Line 245
    01:54:31 #33 TRANSFER -19 File WriterStatus.cpp, Line 245
    01:54:31 #34 Phase 38 File dlgbrnst.cpp, Line 1841
    Burn process failed at 48x (7,200 KB/s)
    Existing drivers:
    File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 11/03/2002 10:55:38
    File 'IoSubsys\CDR4VSD.VXD': Ver=5.3.2.31, size=101616 bytes, created 31/03/2004 22:22:38
    File 'IoSubsys\CDRALVSD.VXD': Ver=5.3.2.31, size=20043 bytes, created 31/03/2004 22:22:38
    File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 30/05/2001 19:04:44
    File 'IoSubsys\CDUDF.VXD': Ver=3.01e (184), size=63869 bytes, created 31/08/2000 03:01:00
    File 'IoSubsys\CDUDFRW.VXD': Ver=3.01e (184), size=151807 bytes, created 31/08/2000 03:01:00
    File 'IoSubsys\CDRPWD.VXD': Ver=3.01e (184), size=49671 bytes, created 31/08/2000 03:01:00
    File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 08/06/2000 17:00:00
    Registry Keys:
    know whats wrong?
  10. Originally Posted by Cobra
    Cobra
    Sometimes I'd rather them NOT ask......
    "Better to be thought a fool, then to open your mouth (in this case POST) and remove all doubt"
    makntraks
  11. Originally Posted by Nero
    There's your problem.
    When we see this happen during DVD burning, it's commonly due to shit media. But I gots to be honest with ya, I haven't seen this error with CD burning in a long time. I suspect that...
    ...this is the problem that generated the failure. Nero didn't like the results it got when testing the media at such a high speed.
    Try another burn, but reduce the speed to 12X or 16X, and see if it works.
  12. Louise01,
    I didnt see what type of computer you have.
    What you really need to do is upgrade to Windows XP Home or Professional. Windows ME will be next to impossible to find things for.
  13. i suggest windows xp too
    it detects and installs the driver automatically for every cdrw and dvd drive i have ever encountered
