just wantedt o know how many of you have converted divs to dvd. and how fast?. im on a pentium3 800mhz and it takes 8hours to convert a movie. it slow, i know, but how long would it take on say a pentium4 2.6ghz or 2.8ghz with 512mb ram. thinking on buying, one but wanted to know if its faster or not.
Can't tell you about pentium4 but AMD 2.1 + 768 ram on w2k just done a divx file of 66mins and encoded it in 50mins at full dvd spec (1pass) .
wow! thats pretty fast. amds are slower then pentiums. so in theory does this mean if a amd 2.1 can do it in 50mins, then a p42.8 should be much quicker.
also do u think memory make a difference. if i have 512mb would conversion be faster if i had 768mb, like u hav. -
I have a celeron 2.6mhz 512 RAM
I convert my stuff using TMPGEnc Plus normally 58 min divx at 800mbs movie takes 115 min So its like 15 extra min. to convert it to a 1/2 DVD MPEG-2 352x480 -
thats not a bad speed thundercrush but ur using a resolution of 352x480 whereas im using a standard ntsc or pal resolution, whcih is approx 720x576 for pal and 720x480 for ntsc.
BTW on my system I noticed a BIG drop in performance (encoding) with winXp. stuck to w2k since
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 04:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 21:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 20:06
