i want to use the kanji buttons that they offer, but i dont want it to be the default blue color. is there anyway to change that to something else??? as well are there more button styles available anywhere else? thanks
The only way I know of is to create your own buttons with a paint program and then when you click on a button in the menu edit window you can navigate to your new button.
Any free tools to author DVD structure with menu buttons?
By p23185 in forum Authoring (DVD)Replies: 1Last Post: 1st Mar 2010, 17:03 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
TMpegEnc DVD Author won't fill a 4.7 GB DVD
By jagojon3 in forum Authoring (DVD)Replies: 12Last Post: 29th Dec 2008, 19:32 -
Menu buttons with different color sets?
By argent77 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2008, 08:58 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
