  1. Since the guide on how to do this is not working, how would I go about inserting my own "insert disc 2" at the end of my dvds. I am splitting the movie over 2 dvds and what to put in my own made image. Any help would be appreciated.
  2. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    What aothering prog are you using
    In dvdlab simplist way would be to make a spare menu add backround of choice and link the return from the movie to the spare menu (prehaps put a button on it to link back to main menu if desired)
    Simple
  3. I am using dvd shrink and figured you could not do what I wanted with that program. I will take a look at dvdlab, but $100 seems pretty pricey for just inserting a "insert disc 2" screen. Thanks for the help.
  4. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    colt4523,
    I have copies of the guides. If you want, I can email them to you. Send
    me a PM if interested. There are two guides: Beginner and Experienced
    You can do this with both DVDShrink and IFOEdit (also freeware).
    -LouV68
  5. DVD-Lab is worth the $100...u will use it for all of ur authoring needs
  6. Ulead DVD Movie Facotry can do what you want and there is a free trial
    If it's wet, drink it
    My DVD Collection
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    PLEASE post dvd to dvd posts in this forum section.
