I am running windows XPand use Cucusoft AVI to VCD DVD MPEG Converter Pro to change avi files to dvd. Then I use TMPGEnc DVD Author and DVD witer to finish. QWhat I would like to know is why do the movies freeze in the middle and nothing can make them go any further? I wondered if I wrote them at a different speed would it make any difference? On the computer in there original avi state they are perfect so it must be something I am doing wrong. Any help would be gratefully received.![]()
Tried what you suggested but it didn't show any bad frames. Any other suggestions?
Check to see if the encoding always stop on the same frame. If it does, encode to just before that frame, then encode after that frame. Then use MPEGTools to join the two encoded parts.
Hello.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
