hey i have a msi geforce4 mx440-vtd8x and it gives me the option to hook either composite or s-video up to the card. it took me a while to figure out how to get everything configured but i finally did.
my question is the only way to play my ps2 on my computer is through video capturing software. it only shows up in a little box for previewing befor i record. thats all fine and dandy if i wanna record but i just want to play the ps2 on the monitor in full screen. im guessing im just not looking for the right software or something so i figured i would come as you guys
Why not get the adapter that lets you plug the ps2 directly into your monitor?
because i never used this option i have on my video card and i felt like using.
i dont feel like spending 50$ on an adapter right now(crazy bills)
if i go through my video card i can record stuff that i do.
i just want to be able to do this. any help would be a great help -
Adapters are under $20 and you get a much better picture,if you want a crappy picture with video in then try a program such as powervcr2.
viewsonic & Planar both make a vga adapter box with remote control so you can use your lcd monitor as a tv.....
some cards let you use your video input as a desktop or a screensaver, so you see it full screen, those might work if you want to plug in your ps2 (ps2 games aren't written for vga, so they don't look much better, kinda fuzzy).
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58 -
Play video in TV and work in Monitor
By mraza in forum Newbie / General discussionsReplies: 5Last Post: 30th Aug 2008, 19:24 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54 -
How to play video on VGA monitor without a PC
By ari dubov in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2008, 15:45 -
_Playing PS2 on widescreen monitor
By sirshafty in forum Capturing and VCRReplies: 4Last Post: 24th Aug 2007, 07:58
