  1. I have backed up 24 season 1. All discs work fine except disc 6. It won't play in either of my two home dvd players or my friends. It will however play on my PC. My PC is using Windows XP Pro, dvd writer is Panasonic DVR-106D and i wrote disc as a dvd-r. Any ideas anyone?
    Jan 2002
    Not the end of the world!
    If all other discs are fine, then I'd say that disc or the burning software is at fault.Rip the disc to your harddrive with DVD Decrypter in ISO Read mode and burn a new copy using again DVD Decrypter in ISP Write mode. That will eliminate the burning software you originally used as a suspect. If you still have a problem then it could be the method you used to back-up the disc. Episode disc are some of the hardest to back-up,
  3. Did you put all the DVD compliant files into a VIDEO_TS folder then burn that folder? If not then that's the problem.
  4. Created video_ts file so that's not the problem. I'll have a go in ISO mode. Thanks both for your help.
  5. Thanks for your advice. It worked first time. Cheers.
