Ok, it's been a while since I've copied any of my home videos from my Sony Mini DV camera to the pc and I've got to get caught up.
I'm looking to see if there are any better (i.e. quicker) methods for getting that Mini DV from my camera to my DVD's.
So, would some of you care to share what methods you're now using to do this?
I use to capture it with Pinnacle Studios in .avi format and then encode it with tmpgenc and that got to be a long process.
Thanks!
DarkCyber
If it's not outside your budget, get a DVD recorder. Doesn't get any quicker than that.
Otherwise, use an all-in-one tool, like Sonic MyDVD or Ulead MF. Speed may come at a cost of quality though. -
Thanks for the suggestion, but not looking for a dvd recorder yet.
I'm just looking at the pc way right now
I guess one of the other questions I meant to ask, is there a program out there that will take it right off the mini dv camera (via my firewire) and convert it to a dvd burnable format with good quality as it takes it from the camera to the hard drive? One of the programs you suggested my do that, I will check on it.
Thanks again,
DarkCyber
best method to encode dvd's
By codemaster in forum DVD RippingReplies: 8Last Post: 9th Feb 2011, 07:42 -
Best method for backing up TV shows from DVD
By android6011 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2009, 20:03 -
Best method for resizing the dvd's video?
By hamid22689 in forum DVD RippingReplies: 2Last Post: 26th Sep 2008, 14:11 -
Best burning app/method for DVD?
By stantheman1976 in forum Newbie / General discussionsReplies: 14Last Post: 25th Feb 2008, 13:04 -
what is the best method to convert XVID TO DVD?
By kobi_af in forum Video ConversionReplies: 8Last Post: 19th Nov 2007, 23:38
