  1. Any idea what the problem is? The only thing I can think of that may have affected the program is that i uninstalled the demo version (been using paid version for weeks, only just uninstalled demo)
  2. I've just re-installed the demo and now the full version is working. This isnt a problem for me and isnt taking any hard drive space that i need.. so i'm happy to live with having the demo installed aswell, but if you want to answer so other people can see what the problem is then continue
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I suspect that uninstalling the demo uninstalls certain registry settings. I also suspect if you re-installed the full version you would also have been ok.
    So ideally one should uninstall the demo before installing the full version to avoid this. Well spotted. I will add this instruction.
    CB
  4. ah right okay!
