Can anyone help? My audio playback (after new Hard drive installed), using Sigma Tel driver. Now gives me a strange audio output:
1 Vocals are in the background and echoey.
2 Tracks sound like they have been remixed!
thanks
To see, one only has to look.
To hear, one only has to listen. -
sounds as though your sound card has some fancy DSP options. open whatever software came with your card and kill any of that crap.
There is no sound card (its on the motherboard), just staight 2 channel sound, there are no other options!
do you have the little volume icon on your taskbar? double click. options. properties. scroll through the list of controls and have a check for "3d sound" or "hyper sound" or just something else silly. enable this, then close the properties window. 3d sound should now appear with all your other volume controls - turn it off!
if that's not it are you 100% you have the latest sound drivers from your mobo manufacturer? -
It is in fact the driver! All sorted now thanks
Very Mixed Requirements
By juliam in forum Newbie / General discussionsReplies: 7Last Post: 5th Jul 2011, 00:15 -
6 channel audio gets mixed up during a point in movie
By Event3horizon in forum Authoring (Blu-ray)Replies: 6Last Post: 17th Jul 2010, 20:49 -
Help! Audio on DVDs plays wierd. Incorrectly Mixed?
By rayden54 in forum Software PlayingReplies: 4Last Post: 18th Sep 2008, 23:57 -
How to make a mixed DVD
By Baldrick in forum User guidesReplies: 60Last Post: 4th Sep 2008, 14:01 -
Mixed Video Formats in Vegas
By SCDVD in forum EditingReplies: 0Last Post: 21st May 2008, 11:10
