I have been converting all my AVI to XVCD and generally have been happy with the quality. I have been thinking about upgrading to SVCD but I am not sure if the difference in quality from XCVD to SVCD is worth the $50 it costs to buy TMPEGenc plus. What do you guys think?
Results 1 to 30 of 34
No, but thats what it costs.
Simple supply and demand - there is no real competition, as soon as a good Mpeg2 encoder shows up cheaper, that will be the end of Tmpeg's high costs. -
Originally Posted by pyscrow"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by thor300
CCE has almost zero features compared to TMPGENC and has a steep learning curve if you want to combine it with AVISYNTH. And to call it "3x faster" is very debatable.
Like FOO said, I'm cheap too, but I bought it. Never regretted it. Probably one of the single most used programs on my PC.Want my help? Ask here! (not via PM!)
It is more than twice as fast, and the encoding quality is better. I cant see whats so difficult about AviSynth, but thats just me. Agree it has no features, but it has what you need, and most important it has quality and speed. Thats important for me and i have no doubt what encoder is the very best.
My extensive tests some years ago put CCE encoding times
at about 60% of TMPGENC. This included the almost mantatory
use of Avisynth or Vdub in front of it. Don't forget to note that
you will have to do your audio separately. That IMHO makes
it about even or worse.
No way in hell it's 3 times as fast
edit: I also tried Quenc lately , and was very surprised at how well it did
and it's free -
The difference is much bigger than your 60%, and doing the audio separatley doesnt slow down the process that much, a full backup can be done in less than 2 hours with CCE, and its not only me, i read other posts stating the same as i experienced. And you dont HAVE to do audio separately with CCE, so your information is a little wrong here and there, its expired at best
I have only my tests to go by
I don't believe anyone else , especially what I read on the internet.
For some strange reason , some people have an emotional rather
than objective attachement to a particular approach.
I put it down to early religious training that teaches that
"my ideas are the best" and the rest are all crazy
2 years ago the TMPGenc vs CCE thing was as bad as the
+ vs - DVD format and nobody ever won that either.
edit: and back then CCE was VERY expensive -
If you are really cheap you can buy TMPGEnc DVD Source Creator for $10 less than TMPGEnc Plus. It is a stripped down version based on the project wizard of TMPGEnc Plus. If you don't need to fiddle with the expert settings in TMPGEnc Plus it might be a good deal. There is a trial version at the TMPGEnc website.
I used to benchmark by encoding 10 minutes of avi file (720 X 576) to PAL VCD using TMPGEnc. It took me 35 minutes on my AMD Xp2100+, 512M byte RAM. Now a 10 minutes video clip takes about 9.5 minutes to encode using TMPGEnc on my Intel P4 3.0C, 512M byte RAM. If you want speed go for the fastest Intel cpu since TMPGEnc supports SSE2 and HT(hypertreading).
Originally Posted by FOO
I am also an elcheapo - Tmpgenc is the only program I use for DVD stuff that is not freeware, so if a reasonable freeware alternative was available I would be there like a shot! -
The problem is not that TMPG is overpriced- it's the freeware that you use is underpriced.
tmpgenc plus is NOT a vcd or svcd author tool. try post in correct forum.
Worth every penny!
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by Craig Tucker
Originally Posted by BobK
Sometimes freeware goes pay, but then you just keep using the last free version, or go on to the next bit of freeware! (Or write your own code, which I do often for simpler things!)
IE DVDfab and Odin duplicate image finder are two programs that are now "pay", I am quiet happy using the last freeware versions, they work! -
So if you think TMPG is overpriced just move on to the next bit of freeware. -
Is TMPGEnc Plus worth $50?
i used Tmpgenc awhile, then tried mainconcept and have used it ever since. i still use Tmpgenc for stuff like (de)muxing and very basic cut/merge projects. love mainconcept though, very fast and great quality.
[edit] of course its quite a bit more expensive, failed to mention that, depending on ur budget u might be better off using Tmpgenc.
josh -
just a thought
mastersmurfie
Is upscaling really worth it?
By bobbysafety in forum DVB / IPTVReplies: 20Last Post: 10th Dec 2010, 11:04 -
What do you think this pc is worth....
By lordhutt in forum ComputerReplies: 3Last Post: 3rd Nov 2010, 07:00 -
Lightscribe worth it?
By newworldman in forum DVD & Blu-ray WritersReplies: 16Last Post: 19th Aug 2009, 18:40 -
Is the Matrox RT.X2 worth it?
By shockaholic in forum EditingReplies: 1Last Post: 22nd Jul 2007, 14:31 -
XP Media worth it?
By 123fish123 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2007, 02:00
