hello,
would there be a way to extract everything from the VOBS of a DVD? i mean is there a program that would extract all the video files, all the audio files all the sub files and the menu files from either a DVD image, or a folder of VOBS?
thanks!
Results 1 to 11 of 11
For what purpose? Most likely you are probably going to create a dvdr, and if so, then DVD shrink is a great program that you can use that will preserve menus, subtitles, audio tracks, whatever you want and fit it onto a dvd5.
you know when you open dvddecrypter, there's a tab labelled stream processing? well in that tab you can enable stream processing.
Makes sense.Originally Posted by flaninacupboard
no more VOBs - but what else?
By slimselecta in forum DVD RippingReplies: 1Last Post: 3rd Aug 2009, 06:50 -
what do I do with the vobs from dvdfab?
By pattirose in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2009, 20:12 -
combining two VOBs into one
By Jan G. in forum EditingReplies: 16Last Post: 8th Apr 2009, 12:27 -
2 VOBS into 1 title
By kshavo in forum Authoring (DVD)Replies: 3Last Post: 19th Feb 2009, 19:03 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52
