I'm trying to convert a mpeg-1 file that that is originally a PAL (352x288)
mpg file to NTSC (352x240) format
I use Tmpeg to convert the video but I read one of the guides from
this site that the audio also needs to be converted from PAL to
NTSC (using BeSweet)
I thought we only needed to convert the video from PAL to NTSC
I'm not sure why the audio also needs to be converted.
Any help on this would be appreciated
PAL comes at 25FPS, this can be interlaced (for a TV show or DV) or can be progressive (for a feature film)
NTSC can be 29.97FPS interlaced and 23.976FPS progressive.
Feature films are shot at 24FPS. so to show a film on PAL we speed it up to 25FPS, and also speed up the audio. so therefore if you want to convert 25fps PAL to NTSC you can slow it down to 23.976FPS and slow the audio as well. this will give you much smoother motion and a better picture all round than trying to convert 25FPS to 29.97FPS.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 11:33 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 08:16 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 19:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45
