I have heard that it's possible to burn a back-up to DVD-R or +R using DVD-Rom bit setting.... Anyone here heard of this ? Supposedly it produces a much better burn and quality is better...
BTW - I meant to post this in authoring section.
Even a fool can be wise, all he has to do is keep his mouth shut
AFAIK, bitsetting only applies to DVD+R and DVD+RW. It doesnt do anything for burn quality/speed or otherwise.
All you can do is bitset the disc as a DVD-R, DVD-RW, DVD-ROM etc. book type. This is to ensure compatibility for older drives and players. Read a few guides or explanations on this site. Its been covered a number of times before.
Also, not every drive is capable of bitsetting. Only a few can. The DVD-writer tab on the left will allow you to search those capable of bitsetting. -
Thanks porphyra !!!
I did check the guides first, and did not see any topic that covered DVD-Rom bitsetting. However I should have searched the forum....
I heard (rumor) via e-mail that DVD-Rom bitsetting was the best way author, just as good as the original disk, can help you shed 15-20 lbs in less than two weeks, and help you quit smoking.....
I'll just stick with my DVDShrink - has never let me down yet !!!
Even a fool can be wise, all he has to do is keep his mouth shut -
LOL..
Bitsetting has nothing to do with authoring. It just applies to setting a booktype while burning. Its really quite useless if you have newer hardware. -
All this does is trick the DVD player into thinking it has a dvd rom.
I remember reading some professional tests on this, and even though setting the bitsetting to dvd rom enabled some dvd players to accept a disc they would otherwise reject, those discs still showed playback problems in those playrs. -
I would say bitsetting is very useful,my dads new apex can now play all dvd+r backups and burn quality is what affects playback so i think the bitsetting tests are subjective to what dvdr you use to burn with.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 19:15 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 11:12
