  1. If there any PC software that allows editing of RGB, contrast and brightness levels? I want to re-encode a set of martial arts DVDs.
  2. The only way I know to do this(because I have to do it often), is to rip the DVD then import the AVI into whatever editing software you are using then reencode. The only problem is you will lose image quality.
    If you have the original footage I would use that.
    true to the tri
  3. Originally Posted by turboman
    Thanks. It's 5 DVDs so that's a lot of work!
