  1. How can I tell what a video file is?
    Apr 2002
    Sydney, Australia
    You should be able to tell straight away just by the look and size of the file if you go into the tools section you will find analyzers like G-Spot.
  3. Member teegee420's Avatar
    Dec 2003
    Southern California
    AviCodec will do the job. G-spot doesn't specify mpeg-1 or mpeg-2, not mine anyway.
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi JackMartinEF,
    Use AVICodec as that works with MPEGs too.
    Look under the blue "VCD" for the MPEG1 specs, and the "SVCD" / "DVDR" links for the MPEG2 specs.
    From these specs, you can tell whether it's MPEG1 or 2. That said, AVICodec tells you anyway, but I guess it's extra info that might be useful...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
