Hello i am still kinda new at this... i was wondering what program can i use to convert my avi to a mpeg file but not totally destroy the quality of the movie.. is this posible?
Results 1 to 12 of 12
Originally Posted by ZippyP.
Go to the guides section for instructions. The quality will depend on the bitrate of the source and the final bitrate you use when converting.If in doubt, Google it. -
Yeah, you need to learn how to encode. Don't be afraid of experimenting. MPEG2 works (as you can see from this forum). Be patient and read guides first.
Originally Posted by simplexx
mpeg2 is the format for DVD.
Sound like you need to try some stuff out, make some mistakes and come back around
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
My movie is originally 576X240 but when I tried to load it into TMPEGenc DVD Author is says its not the correct size... wut size should i make it so it still stay clear and crisp? and will look fine on my tv?
DVD has 3 basic resolutions, 352x240/288 (VCD), 352x480/576 (1/2 DVD) and 720x480/576 (D1). The larger sizes are for PAL. It's all in the "What is DVDR" section.
Go with the middle one for your file."Art is making something out of nothing and selling it." - Frank Zappa -
When I go to play my movie in the dvd player it looks stretched like everyone is extra tall... how do i keep it widescreen like it was before?
Be sure to select full screen (keep aspect ratio). Are you following a guide? If not, I suggest you do.
im using MainConcept but And i got it to work in there but when i put it into TMPEnc DVD author is changes it back to full screen
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
