Here's what I'd like to do:
Connect a DV cam to a pc/laptop via a firewire cable and display the recorded footage on a monitor with a time delay of about 10 seconds (variable if possible).
My thinking is that the computer would only have to store say a minutes worth of footage (as a buffer) in order to play it back with a short delay.
Is this possible and if so, is there software available to do it?
Many thanks,
Dave
they are all about $10,000 except HD , whch is 50,000-75,000$
http://www.doremilabs.com/products/productsdelay.htm
http://www.360systems.com/propdelay.html
http://www.primeimageinc.com/AVD_Spec.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
There must be a way to do it with software. If you can capture footage from the cam in real time then surely you can get the pc/laptop to play it back ten seconds later(??)
I think Avid Xpress Pro has that feature. You might want to check that out.
it doesnt even have real time preview untill it has rendered the file or read it all -- unless you see something i dont ..Originally Posted by DVMaster"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I guess I'm looking for a timeshift feature - like on my Panasonic DMR-E30
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
Delayed Playback - Camera to Laptop?
By Nathan F150 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Jul 2011, 19:13 -
Capture from Video Cam to Computer with Time and Date Stamp
By Larrypi in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2011, 10:05 -
Video Art Installation/Delayed Playback Help
By mrpie42 in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2009, 11:48 -
Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
By gallion311 in forum Video ConversionReplies: 2Last Post: 1st Dec 2008, 10:55
