i have now3 dvd+rw that are not regonised anymore as rewritable
i have tryed alcohol nero but they just can't find them anymore
1 i have aborted during a burn because i chose the wrong movie
1 was overburned by 2 Mb
1 has stopped during erasing
what do i need to make them work again
1. Set 'Ignore illegal TOC' in Alcohol and try again.
2. Try DVD Decrypter. (rightclick on source drive, Erase, ignore the error messages)
3. Erase with DVDInfo PRO -
Most of my DVD+RW and DVD-RW have problems with it. Many have been burned 100% maybe 10 times each. Then, sometimes they will fail in the middle and takes a long time and a miracle to get them to burn again completely and succesfully.
The trick that seems to work 80% of the time is DVDINFOPRO format then burning the DVDs at a lowest rated speed.
Are Premiere processing "byproduct" files erasable? Need advice!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2011, 17:58 -
Hello My dvd shrink 3.2 does not work anymore
By Seekyr in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2009, 20:14 -
DVD player does not play sound anymore
By M_W in forum AudioReplies: 4Last Post: 9th Sep 2007, 05:20 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 23:18 -
Help! My Dvd Player Won't Mp3's Anymore
By Just8 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jul 2007, 00:08
