Hi, I trying to burn several divx files into 1 DVD-R using ISO/UDF setting within Nero 6.xx and the total size is less than 4.3G. For some reason, 1 disk won't come out right, what happens is this after a successful burnt, and pop the disk into the xbox PC DVD-Rom drive. When trying to play the disk using XBMP 2.3, and select UDF, but only 1 or 2 files is display within UDF folder in my xbox??? But when doing the same thing on ISO folder, every files is displayed?? Because i could only played all the files within UDF folder only, therefore within the ISO folder - NOT all files plays correctly. So I stuck here folks, PLEASE help.
Thanks in advc...
Burner: Pioneer 107D
Disk: Ritek G04 Printable
Results 1 to 1 of 1
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 18:18 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 12:23 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
