ive got a movie file on 2 cd's i want to put them on to 1 dvdr. how do i do this ive already convrted them with TMPGEnc. do i just add both files into TMPGE DVD author then burn it when its done, im not really sure. Thanks
Yes that's the theory but you haven'y said anything about what files you have . were the files AVI or VCD ? What have you converted them to?
sorry havn't got my head together yet. convrted them from avi to m2v putting them on the dvd so just need to author them now
OK If you didn't join the files before you encoded them I hope you kept the file size of the two low enough to fit on a DVD-R. If not its not the end of the world.
A m2v file is just the video file you should also have a wav file for the audio.
Open TMPGenc DVD Author -Create new project - add file and add you first part then add file again and add your second part .Create your menu if you want and click output.
That creates your VIDEO_TS foldey with you .vobs etc in.
If it fits on a DVD-R then yes you burn that.
If it is too large you can use DVD Shrink to shrink it to make it fit. -
Sorry I've not had that before normally you don't see the join. Hopefully someone will know and post.
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 10:13 -
joining/making movie from 2 cds into one with AVI,S
By keithportsmouth in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2008, 13:51 -
Joining DIVX files
By jimbb in forum EditingReplies: 17Last Post: 9th Apr 2008, 12:05 -
Joining a movie with 2 parts together using virtualdub!!!
By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 15:09
